Original Tip Date: Jan. 13, 2006
| Relocate view navigation toolbox | |
| Do you yearn to have the view control icons on the left side of each view? If so, then just go to Workspace > Preferences > View Options and adjust the Show View Toolbox/i> option as shown below. By the way, if you havn't guessed by now, this is a MicroStation V8 XM Edition feature. | |
AskInga Tip #609
