Original Tip Date: Sep 26, 2005
| Batch create thumbnails to use in the MicroStation Manager | |
| Here's a cool keyin from Bentley's own Phil Chouinard that lets you create a saved view called Preview for thumbnail generation. Use it with Batch Process and you're all set. With thanks to Thomas Voghera for submitting it here! expand set MS_THUMBNAIL = Preview;save view Preview;selview 5;filedesign Note that in the example above, the saved view is being created from View 5. See also: Set Temporary Variables With The Expand Set Keyin Utilize A Saved View For Your Thumbnail All About Thumbnail Generation | |
AskInga Tip #553
