Original Tip Date: Feb 18, 2005
| Alternate keyin for selview | |
| Tired of using the keyin selview [view number] in your scripts? If so, use point absolute instead. This one uses the "active view" and therefore eliminates the need to keyin a specific view number. For example, instead of using this keyin which relies on you being in the correct view: set lvlsymb toggle;selview 1;update view;selview 1 Use this one - which does not care what view your in. set lvlsymb tohgle;point absolute;update view;point absolute Thanks Rudi! | |
AskInga Tip #488
