Original Tip Date: Jun 14, 2002
Modify a circle clip volume
Using a circle as the clip volume element in V8, and having trouble moving or re-sizing it? Grab it at it's center instead of it's edge. Problem now solved.
With thanks to Bentley's Phil Chouinard for sharing this tip.
AskInga Tip #180 |
