Original Tip Date: Feb 26, 2002
| Scroll your views by distance...sort of. | |
| You can pan or scroll a view by a specified factor by using the following keyins: MOVE DOWN [factor] MOVE LEFT[factor] MOVE RIGHT [factor] MOVE UP [factor] Where "Factor" is the amount of the view to scroll. If the factor is omitted the view is scrolled by the default value, which is 0.25 (or one fourth of the view that you select). To assign these to your function keys, you may want to append the SELV command. For example, to pan 1/4 of the screen down in View 1, the command is: MOVE DOWN;SELV 1 | |
AskInga Tip #136
