Original Tip Date: Dec. 19, 2003
| Can't find the cell origin in cell libraries? | |
| While building a playhouse for his pet kinkajou, Mike Otte found the time to post this tip: To view the cell origin in a V8 cell library, you simply turn on the ACS Tridad in the View Attributes dialog. However, if the cell library was converted from V7 to V8, the ACS triad may not appear. To correct this, go to Utilities > Auxilary Coordinates and change the Type from None to Rectangular. You should now see a mark at the insertion point. | |
AskInga Tip #379
