Original Tip Date: Sep 22, 2006
| Change the annotation scale of selected text/cells | |
| With thanks to none other than Josh Schifter for posting this keyin on the discussion groups: To change the annotation scale of selected text or cells, first put them into a selection set, then use this keyin: annotationscale change [scale] This is a cool way of changing the annotation scale of selected elements rather than all of them via the models annotatation scale. Note, you can look up the value of the scale in ...WorkSpace\System\Data\scales.def. Just open it with a text editor and note the right hand column. | |
AskInga Tip #674
