Original Tip Date: Aug 30, 2006
Use the nearest snap to locate key points on text
With thanks to Mary Bloswick for sharing this on the disucssion groups!
To quickly locate alternate points on text, simply use the nearest snap as shown below. |
AskInga Tip #665
