Original Tip Date: Feb 23, 2005
| Left Margin, Right Margin text justification explained | |
| With many thanks to Patrick Pirtle for sharing this information on the discussion groups! Way to go! Each line of text can have a maximum number of characters which is set with the Line Length command by using the LL= keyin. For example, if you keyin LL=10, select PLACE TEXT and start typing without any carriage returns, the text node will break every 10 characters. Now, if you've set LL=10, have your justification set to Right Margin, and start placing text - your text will be placed at the right end of a 10 character-long line and the origin (or alignment of the text) will be at the left side. | |
AskInga Tip #493
