Original Tip Date: Nov. 25, 2003
| Keyins to set text editor style | |
| Phil Chouinard found these keyins in the bottom of a box of Cracker Jack's: To change the style of the text editor, use this keyin: null;mdl keyin calculat calculator userPrefsP->textEditorStyle=x Where x will be one of the following values in MicroStation V8: 0 for the MicroStation /J style of dialog 1 for the WYSIWYG dialog 2 for the keyin dialog 4 for the Word Processer sytle of editor. OR, use these values in MicroStation pre-V8: 0 for the MicroStation /J style of dialog 1 for the WYSIWYG dialog 2 for the keyin dialog | |
AskInga Tip #364
