Original Tip Date: Nov. 18, 2003
| Define tabs and indents | |
| Snipped from MicroStation V8's Help: The Word Processor Text Editor window has a ruler for setting tab stops and indents. The ruler works like the rulers in basic word processing applications. To open a dialog box for keying in tab stops and indents, right-click the ruler and choose the item in the pop-up menu. | |
AskInga Tip #349
