Original Tip Date: Oct. 3, 2003
| Use the same spell checker dictionary as Microsoft Word | |
| Bentley's Mike Evans shared this on the v8.general newsgroup. Very cool! To use the same dictionary as you would in Microsoft Word, point MS_SPELLINGUSERDICTIONARY to the file being used by MS Word. This would typically be: ...\Application Data\Microsoft\Proof\Custom.dic | |
AskInga Tip #310
