Original Tip Date: Oct. 3, 2003
Convert single lines of text to a multiline text node | |
If you've got several single lines of text that you'd like to convert to a chunk of multi-line text ... meaning a text node ... try this: Put all the text into a selection set Keyin CTRL+C to copy to the clipboard or, CTRL+X to cut to the clipboard as shown below. Select Place Text Do a CTRL+V in the word processor Position the text. | |
AskInga Tip #309
