Original Article Date: Sep 26, 2005
Here's an enhancement of an enhancement of Bentley's Change Text Case from Daniel Rowlands who was at Scott Wilson Railways Ltd. in his former life. In this version you'll find an extra option to just capitalise the first word. With manyt thanks to Karsten Evans for contributing this version.
Download 264.zip and extract prjchangecase_2.mvba from the zip file.
Place the mvba in the folder pointed to by MS_VBASEARCHDIRECTORIES.
Keyin vba load prjchangecase_2 to load the project, or...
Configure MS_VBAAUTOLOADPROJECTS to automatically load the mvba project upon startup.
Keyin vba run ChangeCase_Start to run the macro, or....
Place the keyin on a function key or custom button for quick and easy access.
Refer to Related Articles below for the other version.
This program is supplied as is. This program does not come with support. AskInga, Bentley Systems Inc., and the author of the program assumes no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this program at your own risk.
AskInga Article #264
