Original Article Date: May 18, 2005
Here's an enhanced version of Bentley's Change Text Case from Peter Terrat. Not only does it change the text case, but it also has a couple of nifty variations: Inital Caps and InVeRt CaSe. In addition to this, Peter's the tool also functions more like other MicroStation tools in that it allows you to specify the settings and then select the text.
2005-09-26 Added a link to a different version of same macro. See bottom of article.
Download 247.zip and extract prjchangecase.mvba from the zip file.
Place the mvba in the folder pointed to by MS_VBASEARCHDIRECTORIES.
Keyin vba load prjchangecase to load the project, or...
Configure MS_VBAAUTOLOADPROJECTS to automatically load the mvba project upon startup.
Keyin vba run ChangeCase_Start to run the macro, or....
Place the keyin on a function key or custom button for quick and easy access.
Once loaded, simply adjust the settings and follow the prompts.
Pressing reset will cause the form to reappear - ready for you to change more text or cancelling the application.
This program is supplied as is. This program does not come with support. AskInga, Bentley Systems Inc., and the author of the program assumes no liability for damages direct, indirect, or consequential, which may result from the use of this program. Use this program at your own risk.
AskInga Article #247
