Eliminate extra spaces with unstacked fractions in MicroStation XM
AskInga logo
Original Tip Date: Jul 6, 2007
In MicroStation V8 XM Edition there's a new option to remove the extra space between an unstacked fraction and unit label. You can find it in the Advanced tab of the Dimension Styles dialog as shown in the graphic below.
Related Tip:
Eliminate Extra Spaces With Unstacked Fractions In MicroStation V8
AskInga Tip #725
