Original Tip Date: Mar 6, 2007
Move dimension text above or below dimension line | |
Regarding MicroStation XM: To dynamically move the dimension text above or below the dimension line, navigate to the Dimension Styles dialog and set the following: Dimension With Leader. Then set the Mode to On and the Type to None. Related Tip: Ball And Chain Dimensioning | |
AskInga TIp #702
