Original Tip Date: Apr 15, 2005
Add a description to your dimensions | |
This tip was kindly contributed by Karl Detrick: Have you ever dimensioned something and wanted to add description on the bottom as part of the dimension string? If so, then turn on Show Secondary Units in the dimension style, and edit the lower dimension with your description. Doing this allows you to manipulate the entire dimension string when using the Modify Element command. | |
AskInga Tip #526
