Original Tip Date: Feb 18, 2005
| Dimensions automatically dropping? | |
| If you're dimensions are automatically being dropped when you place them, use these solutions: MicroStation pre-V8: Ensure this option is turned on: Workspace > Preferences > Compatibility > Dimension MicroStation V8: Use one of these keyins: set compatible dimension off OR set compatible off With thanks to Eric Gray and Bentley's Daniel Eng for sharing this information on the discussion boards. | |
AskInga Tip #487 | |
