Original Tip Date: Jul 23, 2001
| Convert tags to text | |
| To convert tags to text: Place a fence around the tag elements and use the keyin: Fence Freeze. For single elements, just use the keyin Freeze and select the tag. This keyin works in both V7 and V8; although for V8 see this tip: Change Tags To Text This tip was origianlly posted to CCM by Jeff Blower | |
AskInga Tip #117
