Original Tip Date: May 15, 2003
| Comma separate dimension text | |
| Oh this is so sweet...and many thanks to Bentley's Josh Schifter for sharing it on the v8.dimensioning newsgroup! To place comma separated dimension text do the following: Ensure that the dimension master unit is set to metric. Go to Element > Dimensions > Unit Format > Metric Format > Units Separator and select the last option from the picklist! That's all there is to it! Note, for old V8 you'll have to go to Element > Dimensions > Unit Format and turn on Unit Separation. Then keyin the following: mdl load calculat;calculator mdlDimStyle_setBoolIntProp dgnDimStyle_getActiveFromModelRef (0), 1, 1046) and save the changes to the dimension style. | |
AskInga Tip #297
