Set line spacing used for label line
AskInga logo
Original Tip Date: Feb. 13, 2003
Set line spacing used for Label Line
In V7, you can adjust the line spacing used with Label Line via:
Settings > Dimension > Tolerance > Lower Margin
In MicroStation V8 2004 Edition, the Lower Margin setting moved to the Text category.
And in MicroStation V8 XM Edition, the setting is in the Format section of the Text tab.
Note that this setting in expressed in text height units and defines the distance between the element and the bottom of the text.
AskInga Tip #239
