Original Tip Date: Oct. 31, 2002
| Reinstating the original dimension value | |
| If you've edited your dimension text to read something other than what's been auto-generated, you can re-instate the original value by entering a * in text editor. Of course, this is when you are using the Edit Text tool. Thanks to Sean for submitting this tip! | |
AskInga Tip #229
