Original Tip Date: Mar. 5, 2001
| Stop dimension text from flipping! | |
| To stop your dimension text from flipping when a view is rotated, use the following keyin. (Note that this has to be set before the dimension text is placed.) mdl l calculat;calc tcb->ad4.ext_dimflg.viewRotation=1 To use with a macro, the command line would be: MbeSendCommand "calc tcb->ad4.ext_dimflg.viewRotation=1" With thanks to David Dennis who posted this to CCM on 01-03-05. | |
AskInga Tip #76
