Original Tip Date: Feb 16, 2001
| Dimension an arc's length | |
| To dimension an arc's length: Use the keyin dimension arc size or select Dimension Arc Size from the Angular Dimensions tool box. Note, you may need to adjust this dimension setting first: Element > Dimensions > Unit Format > Angle > Length This tip originally posted on CCM. | |
AskInga Tip #62
