Original Tip Date: Jun 1, 2007
| Use ESC to cancel commands | |
| AutoCAD users might like this tip... To use the ESC key to stop or cancel the current command, navigate to Workspace > Preferences > Input and turn on Allow ESC key to stop current command Related Tip: ESC To Go Home | |
AskInga Tip #718 | |
