Original Tip Date: Dec 6, 2006
| AutoCAD 2007 Alert Dialog | |
| AutoCAD 2007 offers a new feature called TrustedDWG which will alert an AutoCAD user if the DWG file was not created or edited by their own software. To avoid this inconvenience, open and save the file in AutoCAD or simply dismiss the dialog as you would with any other. | |
AskInga Tip #692
