Original Tip Date: Nov 6, 2006
Quickly export selected elements to DWG format | |
Kirk Dunlap offered this nifty tip on the discussion groups: For those of you who would like to export elements from a DGN to a DWG, try this: Place a fence around the elements to export, or just put them into a selection set. Then keyin dwg wblock Adjust the settings as desired. And, follow the prompts. | |
AskInga Tip #681
