Original Article Date: Dec 19, 2001
Authored by none other than Mr. Barry Bentley himself, this article discuses a variety of techniques to save the file name of a reference attachment with a relative path. This article should be read by anyone who administers the configuration of MicroStation V8.
With many thanks to Mr. Barry Bentley for contributing this article! It's an excellent source of information and will no doubt answer many questions for the users out there.
MicroStation Version 08.00.01.xx includes the ability to save the file name of a reference attachment with a relative path. This capability, along with a discussion of other techniques that have been used in past versions of MicroStation, is described in this document.
Saving Reference File Specifications:
When a file is attached as a reference, the master file to which it is attached must record the name of the file so it can be opened in future sessions. The way that the file name is stored has been the source of some user frustration, and has undergone some refinements as MicroStation has evolved.
The most obvious way of storing the file name is to simply save the full file specification of the reference. That is, if the file is c:\activeProjects\project704\structural\steel.dgn, simply store that full string in the master file. While MicroStation V7 and earlier versions gave the user a way of forcing this result, it has never been the recommended procedure.
The problem with this approach is that it is completely inflexible. If the whole project is moved to a different disk or a different directory on the same computer, then the reference file will not be found. If the project is kept on a file server, then the share point is likely to be different for different users, and the reference might be located on some computers but not others. The only solution is to go into every file and modify the reference attachments for each one.
For this reason, the default behavior for graphically chosen reference files is to store only the file name and extension of references, and then rely on the user or project administrator to set the reference file search path configuration variable MS_RFDIR properly for each project. MS_RFDIR can be set to a list of directories (separated by semicolons), and MicroStation searches each directory for the reference attachments.
The advantage of this approach is that moving a project, or parts of a project, does not require any design file changes. It does require changes to MS_RFDIR. A disadvantage is that MS_RFDIR has to be set differently for each project.
Using Configuration Variables:
Another approach that MicroStation has supported since V4 is to define specific configuration variables and to use the configuration variable to establish the directory in which the reference file resides. For example, consider the following project directory structure:
A project administrator could define configuration variables:
The references could be then be attached by either keying in reference attach P704BORDERS:border_a.dgn or using the Select Configuration Variable option in the Directory menu of the reference file selection dialog. In either case, MicroStation stores the file name as: P704BORDERS:border_a.dgn.
The advantage of this approach is obvious – if the project is moved (e.g., to c:\InActiveProjects\, or to a file server), the only change needed is to redefine the configuration variables. In fact, the astute project administrator would probably set his configuration variables like the following image and then would need to redefine just PROJECT704 – the other configuration variables redefine themselves automatically.
Configuration Variable Relative File Names:
An enhancement made in MicroStation Version 07.01, was to allow reference files to be specified “relative” to a configuration variable. Thus, given the directory structure in the example above, the project administrator could define a single configuration variable, PROJECT704, and a the reference above could be attached using the keyin reference attach PROJECT704:borders\border_a.dgn.
The advantage to this approach is that there is only one configuration variable, so users don't have to think much to know which to use.
There are two disadvantages to this method. First, there is no convenient way to get this result when selecting a reference file using the reference file selection dialog. Second, it “locks in” the project directory structure. The entire project can easily be moved to another root directory or file server, but the internal directory structure can only be changed by making changes to reference attachments.
An interesting variant of using configuration variable relative file names is using the built-in configuration variable _DGNDIR, which always points to the directory of the current master file. The advantage is that there is no need to define any configuration variables, but the same disadvantages above still apply – the internal project directory structure must be stable, and there is still no way of getting this result from the graphical file selection process.
Master File Relative File Names:
In MicroStation Version 08.00.01, there is a new capability for storing the reference file names relative to the master file. This effect is similar to that described above when file names are stored relative to the configuration variable _DGNDIR, but there is a distinct advantage when V8's live reference nesting is used. If the master file references a file in another directory that has its references stored relative to _DGNDIR, those nested references won't necessarily be found because _DGNDIR now refers to the directory of the master file rather than the directory of the top-level reference file. Version 08.00.01 stores the relative path directly to avoid that problem.
Another advantage in Version 08.00.01 is the addition of a toggle in the Reference File selection dialog that tells MicroStation to store the relative path to the design file. The toggle is labeled “Save Relative Path” and appears at the lower left of the file selection dialog. In version 08.00.01.16 and later, you'll also find a configuration variable MS_DISALLOWRELATIVEREFPATH that removes the Save Relative Path option from the reference selection dialog when it's set to 1.
Using relative paths eliminates the need for defining project-specific configuration variables or redefining MS_RFDIR, but, as pointed out above, it limits flexibility by requiring that a project maintain an unchanged internal directory structure.
Relative paths should not be used for references to design files that are in another project, or are shared between projects.
V8 Reference File Searching:
To complete the discussion of how reference file locations are stored and used by MicroStation, this section describes the process that MicroStation uses to find reference files in V8.
For each reference file, MicroStation stores a file specification in the reference attachment. The stored file specification is displayed to the user in the File Name column of the References dialog. When a reference file is attached, MicroStation examines way the file was chosen and decides what to store for the file specification that will give the user the best results in terms of flexibility and maintainability.
Beginning with MicroStation V8, MicroStation also saves the full file specification of where the reference file was located. This is very convenient for the user attaching the reference file, because it means that they will always be able to locate the reference file when they reopen the master file (unless, of course, they move or delete the file). However, because other project participants might not have the same directory structure or file shares, the full file specification might not enable them to locate the file. Therefore, this behavior can be prevented by setting the configuration variable MS_DISALLOWFULLREFPATH, and many project administrators choose to do so.
When MicroStation opens a file, it searches for references files in the following places, in order:
This search algorithm is designed to maximize the chances that each project participant will find the correct reference file.
AskInga Article #72
