Original Tip Date: Nov 19, 2007
| Unlock angle preservation when modifying fence vertices | |
| With thanks to Dinesh Shetti for sharing this on the discussion groups. When using the Modify Fence tool with the modify mode set to Vertex, you can unlock the angle preservation by tapping the ALT key after selecting the vertex to modify. Related Tip: Unlock Angle Preservation When Manipulating Handles | |
AskInga Tip #750
