Original Tip Date: Sep 26, 2007
| Hatch selected areas dynamically | |
| To dynamically select the area to hatch, set the method to Flood and enable Locate Interior Shapes and Dynamic Area Locate in the extended settings. Related Tip: Hatching Alternating Areas With thanks to Robert Janssen for submitting this MicroStation XM tip. | |
AskInga Tip #742
