Original Tip Date: Jul 17, 2007
Draw Revision Clouds in MicroStation XM | |
To draw a revision cloud in MicroStation XM, go to the Drawing Compostion task and select either Cloud by Points (S) or Cloud by Elememnt (D). Adjust the settings and follow the prompts. You can also launch these tools via Tools > Annotation > Cloud. Related Tip: Draw Revision Clouds In Pre-XM MicroStation | |
AskInga Tip #730
