Original Tip Date: Oct 3, 2006
| Construct a circle tangent to three lines in pre-XM | |
| With thanks to Daniel MacNeil for sharing this tip on the discussion groups: To place a circle tangent to three lines, use this keyin: construct tangent circle 3 Note the options avialable with the construct tangent keyin. Who knew? Related Tip: Construct Tangent Circles In XM | |
AskInga Tip #677
