Original Tip Date: Feb. 9, 2006
| Copy selection sets with the CTRL key | |
| You know how you can move a selection set by just grabbing and dragging it eh? Well, in MicroStation V8 XM Edition, hold down the CTRL key to copy the selection set rather than moving it. Note, you'll want to start dragging it, and then hold down the CTRL key. You'll know if it's working by the little plus sign beside the cursor. Related Tip: Make Copies Of Your Raster Attachments | |
AskInga Tip #633
