Original Tip Date: Apr 15, 2005
| How to draw a line perpendicular to an arc at a specific point | |
| This tip has been brought to you today by none other than Shawn Foster: To draw a line perpendicular to an arc at a specific point, follow these simple steps: Turn off AccuSnap. Select the Intersection Snap as your default snap mode. Set Perpendicular Snap Point as the snap mode override. Snap once to the arc, but do not accept. Snap to the line, and accept. Complete your line. | |
AskInga Tip #527
