Original Tip Date: Nov 19, 2007
| Modify reference clip boundary | |
| If you've used a fence to clip a reference, you can quickly modify the clipping boundary as follows: Enable Treat Attachment as Element for Manipulation in the References dialog. Then drag the handles on the clipping element to a new location. | |
AskInga Tip #748
