Quickly toggle the display of references
AskInga logo
Original Tip Date: Jul 4, 2006
With thanks to Greg Atkins for suggesting this tip!
In MicroStation V8, you can quickly and easily toggle the display of references with these keyins:
When using standardized logical names such as PLN, GRD and so forth, use this keyin:
reference display toggle [logical_name]
For example: reference display toggle GRD To toggle the display off all references, use this keyin:
reference display toggle all
You can use also use this keyin to invert the display of all references as shown below.
AskInga Tip #656
