Original Tip Date: Nov. 24, 2005
| Keyin to make a nested attachment a direct attachment | |
| Here's the scoop from Barry Bentley: Specify the nested reference you want to make a direct attachment by giving the "path" to it. For example, if your master file has A.dgn attached to it, and B.dgn is a nested reference of A.dgn, then the syntax of the keyin would be: reference makedirect A.dgn->B.dgn Since this keyin requires a datapoint to accept the change, slap a point ab on the end of it. | |
AskInga Tip #563
