Change hatch symbology
AskInga logo
Original Tip Date: Feb. 13, 2004
MicroStation V8.5 - To quickly and easily change the symbology of hatching, select Modify Pattern, enable Attributes and select the hatch. The hatch will adopt your active attributes.
AskInga Tip #400
