Original Tip Date: Jun 13, 2002
| Measure a distance with Copy Parallel | |
| MicroStation V8 - Forgot to measure a distance before using the Copy Parallel tool? No problem with the new Define Dist button. Just enter two data points to define the distance and it's automatically entered for you in the Tool Settings window. Can't get any easier than that! | |
AskInga Tip #167 | |
