Original Tip Date: Oct 17, 2001
| Draw Revision Clouds in pre-XM MicroStation | |
| Need to draw revision clouds and are tired of using the "tree" custom line style to do so? If so, then look at these resources: http://nesin.net/salient/ http://www.markstefanchuk.com/cadgurus.aspx http://selectservices.bentley.com/en-US/Support/Downloads+And+Updates/Bentley+Library/ Related Tip: Draw Revision Clouds In MicroStation XM | |
AskInga Tip #123
