Control pattern-hatch placement
Original Tip Date:
Apr. 20, 2001
Control Pattern/Hatch Placement
When using
Patterning
or
Hatching
tools, you can control the origin by following these easy steps:
Select the tool
Adjust the necessary settings
Select the element with a datapoint
Snap to the desired origin location
Accept it with a datapoint
Reset to complete
AskInga Tip #90
