Original Tip Date: Feb. 16, 2001
Place an arc tangent to another element | |
Need to place an arc tangent to an existing element (and not using the Place Arc tool? Then use the keyin Construct Tangent Arc. | |
In MicroStation XM Edition and later, you can use the Place Arc tool to construct a tangent arc. Set the snap mode to Tangent or Tangent Point. |
AskInga Tip #21
