Modify - sweeten a b-spline
Modify / Sweeten a B-Spline
To modify a B-Spline curve so that there are no points lying on the curve, use the undocumented keyin
CURVE SWEETEN
. The will also change the shape of the curve within the specified tolerance setting. With thanks to Bentley's Glenn Fernandes!
AskInga Tip #65
