Original Tip Date: Feb 25, 2005
| Attach references from current working directory faster | |
| With thanks to Uncle Phil for sharing this tip: To attach a file from your current working folder, click ALT + D then 1 from the Attach Reference dialog. As you can see from the clip below, this sequence of keystrokes selects the first entry in the Directory menu option. | |
AskInga Tip #494
