Original Tip Date: Mar 14, 2008.
| Keyin to lock the active element template | |
| In MicroStation XM you can either set or lock the active element template. To lock it with a keyin, use one of these: lock templateassociation toggle lock templateassociation on lock templateassociation off When locked, the Active Element Template icon is highlighted with a depressed background. With thanks to Dean for sharing this on the discussion groups. | |
AskInga Tip #753
