Original Tip Date: Jan. 5, 2006
Drag and drop into Attributes tool box to match attributes | |
MicroStation V8 XM Edition offers a neat way for matching an elements attributes. To set a single attribute, simply drag and drop the element onto the desired picker (level, colour, weight or style). If you want to match all of them, drag the element into the Symbology Preview window. Related Links: Match Element Attributes Using The ALT Key Match Stuff Under Your Cursor In V8.5 | |
AskInga Tip #580
