Original Tip Date: Apr. 22, 2004
| Keyin to attach file to itself as a reference | |
| V7 - To quickly attach the file to itself as a reference, try this keyin: RF=_DGNDIR:,,;reset With MicroStation V8, you need at least five arguments to satisfy the RF command, so to attach a model called border coincidently, use this keyin: RF=_DGNDIR:,border,,,*;reset | |
AskInga Tip #430
