Original Tip Date: Apr. 2, 2001
Change non-snappable elements to snappable in V7
Here are a couple of ways to change non-snappable elements to snappable when using MicroStation V7.
			- Modify the snap property in the Element Information dialog.
				(Note that this does not work on text elements)
				 - Use Edg with the following commands:
				SET SEARCH/PBITS= nosnappable
				MODIFY PBITS=snappable
				 - Use MakeSnap from BEusers.com.au.
				I believe that the original author of this little utility is Bill Steinbock
Askinga Tip #84
