Display references with greater clarity
AskInga logo
Original Tip Date: Dec. 8, 2003
MicroStation V8 - Got too much to look at? Can't keep your references straight? Try setting the Reference Presentation to something other than wireframe.
The image below is a screen shot of the delivered ArchComposite.dgn. The left side shows all of the references "as is" while the right side shows the MechComposite attachment in filled hidden line. Quite the difference.
With thanks to Bentley's Lawrence Eaton for this suggestion.
AskInga Tip #369
